Santa is comin Early.....AFC GB....
Status
Not open for further replies.
protegeric said:
What hood is this? I saw it on an MAM banner on their website. Anyone know a website for it or brand name or anything? I`m guessing it`s APC, but are the air ducts functional? http://store.summitracing.com/default.asp?target=/egnsearch.asp&N=400375
Looks like the Xcelerated Concepts hood... So sweet looking in my opinion. Crazycaker designed apparently, Tekkie has it i guess, i found this link on an old thread.
http://public.fotki.com/tekkie/my_car-1/cf_hood/
me and one other guy wanna get the Xcelerated hood, we were talkin about ordering two so we could get a break.... hmmmmmm.....
MSP Kirk said:
We should get a group buy going for this hood! haha (thumb)
hood = teh sex, and protegeric, the "msp" thing in your sig made me laugh so hard i spewed sprite out of my nose... and it's 2:05 in the freakin morning... (screwy) (thumb)
YL you should of gotten an invoice already...Send me your info again and I'll double check.
On another note.........AFCS ARE IN!!!!!!!!!!!!!!!!! They should be shipping out towards the end of next week. Canadians and all others with special shipping arrangements please send me an email by monday reminding me of the special shipping that we had arranged.
Alright!
I HAVE REPUTATION POINTS?! What happened? \/\/ () \/\/ ! I was at 10 for a LONG time, then went to 0 for a LONG time. I was afraid I was just gonna go negative or somethin`. Thanks whoever gave me rep. points! *single tear*
DSM, did you remember our convo on the phone about richening mine up based on my mods?
Also, this Airflowtech person, does he/she respond to PM's? I PM'd him like twice with questions and never got a response...
as did i and recieved no response. but i believe the maps already come slightly richened for mods... either way i don't have enough to need it! lol good luck to everyone with their AFC's
My tech guy, Russ, is on vacation so I've been trying to catch up and cover for him, so sorry about the delays in responses...yes genius I remember our conversation and have the notes from it...
Harness
How do I put pictures up so that they show up in the post on the page? I`m gonna try to post some pic.s of the little wiring harness I made and I don`t know if they`ll come up on the post like I want `em to. So, let`s see. If they don`t someone tell me how.
Harness
Well, you have to start by unCLIPping the MAZDASPEED kick panel (I forgot the name of it, I`m guessing kick panel). Just carefully pop it up. There`s a picture of the bottom side of that.
Then, you pop out the clips holding the plastic pieces in next to the bottom vents and directly across from that.
Next, PULL back the carpet and unscrew 4 (FOUR) nuts from the metal ECU cover. The tops ones are easy enough but the bottoms are hidden by the carpet. There`s a pic. of that.
The ECU is held onto the plate by 4 (FOUR) nuts with brackets, just undo those. Easy... pic.s.
The ECU has a bolt on the top and a black plastic cover. The bolt just comes out and the cover just unclips. Pic.s of that...
or you can just upload them... (reply to the post and scroll down and click manage attachments, then find the pic and click upload)
Harness
NOW for the fun part, IF you are going to do a wiring harness like I did; you will need to cut the wires up as high as possible (up to where the bundle goes into the black tape etc.). Cut the wires, strip `em, put the wires togehter close and twist then solder them back together. And a word of advice from someone who`s done it, if you are going to tin the wire then solder the plug pin on GO EASY on the solder. Do a GOOD JOB, not an overachieving job. I wish someone would have told me this. The pin will likely not click all the way into the plug if the solder winds up on the outside of the pin instead of where u want it, in between the wire and pin, or the wires together may not go into the pin and that is not a good thing.
I used a setup where the O2 and MAF are on their own plugs and the other three wires are all together, but a 5 or 7 or whatever all in one would probably be easier. The only problem is you would have to make a little jumper for the MAF and O2 if you unplug the AFC. There are a couple of different ways to do this. The O2 is a shielded wire and has other wires around it (it`s a MESS!) I just cut `em and used a little piece of wire to put `em back together, I don`t know if this is necessary, then used a little black tape.
I made this sound all real easy, but it was a PAIN. If things fight with you, expect to take AT LEAST an hour.
BUT, the result is pretty much worth it. When I was done, there are plugs sittin right there stickin out from under the carpet easy to get to. PIC.S!
Status
