rough idle
mymp5 said:
not as bad but it seems to be worse the less gas is in the tank i do not go below 1/4 tank but that is when i seems to do it worse thats why i though of the filter but since it is internal i can call that one out the window. i might just call the dealer and order those plugs and see how they work. i really appreicate the help
did you clean both the IAC and EGR? If so how dirty were they?
If that's the case, then rule out my idea of it being the plugs because if it were because of those damn screws, you'd be idling rough regardless of how much fuel is in your tank.
