KrayzieFox
- 01 MP3 Turbo
I drove my car yesterday for the first time in over a month, and a couple minutes into the drive I pull up to a stop light and it starts idling like crap. I had to keep my foot on the gas to keep it from stalling -- RPM were dipping down to 200-500 range, vacuum was bouncing around -10 inHg, and AFRs were in the 17's -- it was choking, sputtering, shaking.. worst idle I've ever experienced.
So I start to head back home and it goes away, then it comes back, then goes away for a while, then comes back again, and finally I get a CEL. I pull into an Auto Zone and they read it as P0401, insufficient EGR flow, which I wasn't too surprised at but I wanted to ask you guys to share your experiences with clogged EGRs. I had it happen on my P5 and the idle wasn't nearly this bad, it was more of a hiccup as I remember, the car would nearly shut off yesterday!
I also wanted to see if anyone has installed the revised Canadian EGR with the coolant hoses and had success in eliminating this problem. I know when I clean the OEM valve it will just get stuck again, so I will gladly spend $100 and get rid of the problem forever if the new valve works as well as it's supposed to.
