As promised in the roof rail thread, here is a little how to install the roof rails (not that it is necessary since the instructions are pretty clear)
sorry for my english, french guy here.
1) First clean the car always more fun working on a clean car
P1020033 by ZuluCx, on Flickr
2) take a flat screwdriver and put some tape on the tip
P1020034 by ZuluCx, on Flickr
3) insert the screwdriver between the front windshield and the tip of the rail (very easy, no real risk to scratch anything) and pry up, the rails will come off.
P1020035 by ZuluCx, on Flickr
4) as you can see, is is plastic with a metal backing, not what I expected, I thought the were all rubber.
P1020038 by ZuluCx, on Flickr
5) mark the three cuts on the rail 340, 501 and 1532mm, I put some tape on the rails before cutting.
P1020036 by ZuluCx, on Flickr
6) put back the rails pieces on the car leaving some space for the bolts brackets
P1020037 by ZuluCx, on Flickr
P1020041 by ZuluCx, on Flickr
P1020040 by ZuluCx, on Flickr
P1020039 by ZuluCx, on Flickr
7) put the roof rails on top (easy to do, and thigh up the 4 x 10mm nuts)
P1020042 by ZuluCx, on Flickr
P1020043 by ZuluCx, on Flickr
8) put the cap on, they just clip in
P1020044 by ZuluCx, on Flickr
9) do the other side!
P1020049 by ZuluCx, on Flickr
P1020048 by ZuluCx, on Flickr
10) put your rack on!!! I am using 450 Thule feets with 60 inch load bars, 50 would be enough but as you can see I have a lot of stuff.... My IBIS Mojo MTB, Look road bike and 2 kayaks.
P1020050 by ZuluCx, on Flickr
P1020055 by ZuluCx, on Flickr
P1020057 by ZuluCx, on Flickr
as you can see nothing complicated!
