get some fresh wax on there for maximum aerodynamics! just make sure to let the car idle for a few mins after long drives. and make sure you have the proper tire inflation.
Bring a quart of oil and check your oil when you gas up. (you should be doing that anyways with an FI car) I would blue tape the front end. But thats just me. Oh and on a serious note, get some gummy bears!
well if you have a real front mask like i do you dont need it, but if you dont it just adds a little bit of protection just in case you get into some bad roads to you dont get all chipped up.
Do it right and get the car clear armored - 3M makes an awesome clear polyvynol masque that goes over the nose its about 600$ installed usually Porsche , Ferrari etc owners get it because its the first and last word in front end chip protection and its nearly invisible and removable withoutdamage. It also covers the outside of the side mirrors , the gas cap , and the front area of the rear tires . Stuff rocks . well rebounds them.....
Yeah thats true , you could buy a black masque that flaps and vibrates and looks like a freshman high school cheap car add-on --- Im not putting you down --it will work and serve the purpose , however if you want a slick , clean and professional long term solution that wont damage the car as those "bras" tend to do from vibrations get the clear armor. + Its invisible unless you get up on the car with a mag glass.
