Kansei said:I've never used anti-seize on the plugs for this car, but yeah some people do I guess?
As for how far to tighten them, it says right on the box. We have an aluminum head so you basically just hand tighten them and just go a little bit farther (1/16th of a turn or so) with a wrench handle on the extension. To do the plugs on this car, since you haven't before, you need a spark plug socket with the rubber insert to get the stock plugs out, they are very deep in the holes. You also will of course need a decently long extension that fits on your spark plug socket.
newprot5fan said:Hmmm....What is this rubber insert that I need?
Kansei said:it sits up inside the spark plug socket so that it grabs onto the white part of the plug as you pull it out. Since the plugs are so deep in our engines are are vertical, it's the only easy way to pull them out. Any auto parts store or like a Sears Hardware store should carry them (there are different sizes). Not exactly sure on the size we use, but I do know that most spark plug socket sets sold in the states are imperial but our plugs are actually metric.. but it's some size in millimetres that it nearly a dead on conversion to inches.
newprot5fan said:OK....
So just out of curiousity, how hard is it to take off the rubber caps to the spark plugs on numbers 1 and 3 (# 2 and 4 don;t have that rubber cap)??? Since I have never done this before, I don;t want to use too much force to yank them off but they sure as hell won;t come off easy. Do I just rip them off no matter how hard it is?
chuyler1 said:Miles/Kms per tank is a useless stat. Please calculate your mpg properly. Run until empty. Fill the tank up completely (2nd time pump shuts off). Reset your trip. Run to empty and fill up again. write down trip mileage and number of gallons put in the car. Divide miles by gallons to get immediate results. For more accurate results repeat the process several times and sum gallons, sum mileage, and divide. On my P5 I usually get 28-31 mpg but it has slipped a little toward the low end now that the car has 76K miles on it. My MS6 gets 19-20 thus far, woohoo.
chuyler1 said:You have to fill up completely before attempting to track mileage (that's once) and then you have to fill up again after you have tracked mileage (that's twice) to find out how many gallons you used since your last fill-up. You can call it whatever you want but you have to start with a full tank, drive, then fill it up again.
I also recommend running until the light comes on or at least 1/4 tank. You will find you get better mileage on your second half of tank than your first (most likely due to weight).
Kansei said:yeah just give them a good yank. if there wasn't any dielectric grease on them they can be really tough to get off.
Tasty said:I really don't get all the whining in this thread anyway. Our cars were only EPA rated at 25city/31hwy mpg. If you're in that range then you're pretty much on. I get 31.2 in mixed driving. That's solid the last 3 times I've calculated it.
