I was able to twist open this big round cover. Inside looks like the HID light. It moves left and right when I push it. I think that's the directional feature of the bulb.Near as I can tell, you just stick your hand under the fender, unhook the wire, then twist and remove the bulb,
 www.reddit.com
					www.reddit.com
				Pish-posh! On our 2014 I replaced the low beam (projector) bulbs with HID units and did it without removing anything else. It's a pain, I agree, and I may have sacrificed some blood to the God of Mechanics, but it IS do-able.These instructions detail the removal of certain parts in order to more easily access the low beam bulbs. On the LH side, you're supposed to remove the fuse block, and on the right hand side, you're supposed to remove the windshield washer tank bracket.
If the headlamps on your 2014 were not HID to begin with, then maybe the mounting is different as ours swivel from side to side when turning and there is a mechanism for that?Pish-posh! On our 2014 I replaced the low beam (projector) bulbs with HID units and did it without removing anything else. It's a pain, I agree, and I may have sacrificed some blood to the God of Mechanics, but it IS do-able.
Oh, wow, I wasn't even aware that those were available back then. But, no, my Touring/Tech does not have that.If the headlamps on your 2014 were not HID to begin with, then maybe the mounting is different as ours swivel from side to side when turning and there is a mechanism for that?
Thank you so much. I'll take a read. Are there any videos online that show someone doing this? I can't find any HID bulb replacement videos for the CX5. Feels like a huge pain to get that part replaced without having to dismantle part of the car, which I've never done and want to avoid.Process can be found here: Mazda CX-5 Service & Repair Manual - Headlight Bulb Removal/Installation - Exterior
It's about halfway down the page, starting at step 8 for HID bulbs. These instructions detail the removal of certain parts in order to more easily access the low beam bulbs. On the LH side, you're supposed to remove the fuse block, and on the right hand side, you're supposed to remove the windshield washer tank bracket. Ensure that you disconnect the negative battery terminal before working on the HID lights, and be sure to clean the bulbs with isopropyl alcohol and avoid touching the glass part of the bulb during the installation process.
One owner mentions jacking the car up and removing the wheels to pull the fender liner back, then reaching up to more easily access the bulb, instead of removing the fuse block and tank bracket (see link below). You might be able to get enough room by just cranking the wheel all the way to the right or left and then pulling the liner back.
Reddit - The heart of the internet
www.reddit.com
And don’t grip / touch the glass part of HID bulb with your fingers directly when you replace the bulbs.Thank you so much. I'll take a read. Are there any videos online that show someone doing this? I can't find any HID bulb replacement videos for the CX5. Feels like a huge pain to get that part replaced without having to dismantle part of the car, which I've never done and want to avoid.
On YouTube, there's a video from Precision LED, "Mazda CX5 LED Headlights and Fog Lights- How to Install (2013+)". I assume it would apply to HID also.Thank you so much. I'll take a read. Are there any videos online that show someone doing this? I can't find any HID bulb replacement videos for the CX5. Feels like a huge pain to get that part replaced without having to dismantle part of the car, which I've never done and want to avoid.
