I have recently bought a 2012 CX9 GT AWD. I had the dealer instal an OEM remote start as they didn't have cars with factory ones available.
The dealer put in Python 4203P. Now I have 3 issues with it:
1. Sometimes the engine won't start at the first attempt. It usually does the second time around (automatically).
2. My original key fob will not open the door once the engine has been started using the python transmitter. The only way to open the door is using the python remote.
3. Once in the car even after i turn ignition on and press on the brake pedal, the red KEY light won't go out as if the original key fob was not detected.
My expectation would be that my original key should always be operational and detected once the ignition is turned on.
I'm not sure if Python 4203P can't be programmed to do that or the dealer didn't install it properly.
Any advice will be greatly appreciated.
Thanks,
Luke
Thanks,
Luke
