blynzoo said:Change your plugs, and (if you feel like it), do your air filter. All this is outlined in the maintenance schedule in your owner's manual.
Also, since it's been 10K, rotate your tires again. If the first rotation was an X rotation, this one will just be front-to-back on each side. You can do it yourself.
Brakes will go sometime between 20-34K miles, depending on your driving. If you feel like it, do that, too.
gizzard said:Another question semi-related to maintenence:
The owner's manual recommends the tire pressure should be kept at 34 PSI. My dad claimed that he checked my tire pressure the other day (in the morning, before it was driven) and found it at 38 PSI. He said it was "dangerous". Is there any truth to this? Why or why not?
I believe the manual says 32 psi if it's a protege5. 38 is not dangerous because the max is like 50 (not sure, but it says on the tire). The bad thing about over inflating is that you'll have abnormal tire wear-basically a strip down the middle will wear.gizzard said:Another question semi-related to maintenence:
When I overinflate my tires, I tend to have less traction -- wheels break loose when trying to accelerate, vehicle slides in cornering.gizzard said:I understand that an underinflated tire can be dangerous because the sidewalls will weaken and "roll over". Is there a point when a tire can be overinflated? What are the dangers?
