eskimo0101
- 2012 Mazda CX-9 Touring AWD
Starting to think spring here in WNY and that means soon I'll be pulling the boat out of storage. One problem, no hitch on the new to the family CX-9.
It's a Touring AWD with the radiator code for 3500lb towing so I picked up the factory Mazda wiring harness and liked the look of the Hidden Hitch the best. Reese and Hidden Hitch are owned by the same company, look identical, but you can get the Reese online from Walmart for $117 and free shipping.
Took a quick look under the car and decided to drop the spare tire to give myself more room. Then backed it up on the ramps I've had since I was 16 and got to work.
Before I tried to hang the hitch I ran a bolt into each of the factory frame nuts to make sure I wasn't dealing with any thread corrosion issues. No problems found, but if they were now is the time to run a tap through to chase out the threads, not when you've got half the bolts holding the hitch in the way.
The passengers side bolts are a little tougher because the spare tire winch prevents using a ratchet. I just ran these in with a large 19mm box end wrench. I've seen a lot of complaints about there being a gap because the hitch was "too narrow". There was a little play when the bolts were loose but once they were tightened down the way you're supposed to tighten hitch bolts the gap was totally gone.
Here's the end result after about a 30 minute install, including the time to dig out my ramps. Really happy with the way the most of the hitch is hidden. I'm still debating on the receiver chrome piece but it just snaps on so if I start to hate it I'll pop it off. Right now I think it goes well with the exhaust tips.
