recomended gas?
I use the cheapest one for my 7......I would guess it wouldn't make any difference since RX8 is a rotary. Our engines burn much, much hotter than cylinders.
10:1... 91 Octain Or Better...
<table border="0" cellpadding="0" cellspacing="0" width="100%"> <tbody><tr><td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Configuration[/font]</td> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif] 1.3 Liter Water Cooled Two-Rotor Engine[/font]</td> </tr> <tr> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Valvetrain[/font]</td> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Not Available[/font]</td> </tr> <tr> <td height="17" width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Displacement[/font]</td> <td height="17" width="50%">[font=Verdana, Arial, Helvetica, sans-serif] 1308 cc / 301.5 cu in[/font]</td> </tr> <tr> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Power[/font]</td> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif] 186.4 kW / 250.0 bhp at 8500 rpm[/font]</td> </tr> <tr> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Torque[/font]</td> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]216.0 Nm / 159.3 ft lbs at 7500 rpm[/font]</td> </tr> <tr> <td height="16" width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Bore[/font]</td> <td height="16" width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Not Available[/font]</td> </tr> <tr> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Stroke[/font]</td> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Not Available[/font]</td> </tr> <tr> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Compression Ratio[/font]</td> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]10.0:1[/font]</td> </tr> <tr> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Bhp / Liter[/font]</td> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]119.13 bhp[/font]</td> </tr> <tr> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]Redline[/font]</td> <td width="50%">[font=Verdana, Arial, Helvetica, sans-serif]9000 rpm[/font]</td></tr></tbody> </table>
it does make a differance, higer 93 is safer than 91, if it detonats at all, those carbon abexi seals will get a beating, and if they screw up, need a new engine..
yeah, but the old rotarys didnt have all the new technology that the 8 has, ex: 3 stage intake..
the 10.0 compression ratio of the 8 is a lot higher than any previous NA rotary engines
the owner's manual recommends premium unleaded gasoline (91+)
you *can* run regular on the 8, the ECU will retard timing to prevent knock, but you risk filling up with less than high quality 87, which will result in knock/ping/things that happen when you fill up with bad gas, and you KNOW rotarys don't take too well to knock :p
I always use premium on the 8, it's like $2 difference compared to filling up with regular, if you can afford an 8, you can afford that extra $2 for better knock protection AND better performance :p
whatever premium is in your area (91+). we have 93 here. be prepared to become very familiar with the gas station because your only going to get about 18mpg out of a tank about the same size as the p5.
