I know that there has been a lot of debate over recirculating the BOV behind the MAFS to aviod the stalling of the car. I thought it would make s significant difference, so I went ahead and had it done. Cost me less than $10 worth of hardware from Home Depot (a couple of hose clamps, some hose, and a small pipe). Hopefully all Spool kits in the future come this way.
Yup, you guessed it..the car no longer stalls. Or even comes close. It doesn't dip below 900rpm ever. So BEAVIS: Yes, go ahead and get your 9lb flywheel if you wish.
I had the guy who did my exhaust today (which, BTW if you live within a few hours of Trenton, NJ, and want to boost your car, this guy is THE man...and is looking for Proteges to boost) do the work to recirculate the BOV, and I had him cut about 1" of pipe out of the center of my Spool intake (compressor->MAFS) so it could fit better, and when he cut it, I had him "straighten" the pipe so that it only bends in 2D, and doesn't "twist" on a 3rd axis (Spool owners will know what I mean). You'll be able to see what was done in the attached pic. Note that I have temporarily relocated the coolant resivoir.
My ONLY problem since I did this is the following...
I took the washer I had in the BOV out (was using it to tense the spring more), but since I did, I hear the BOV venting air at 10Hg. That's way too early. Now theoretically that shouldn't matter since it's recirculated, and drivability wise, I don't notice a difference. HOWEVER, my problem is that when I punch the throttle and start boosting, it JUMPS to 3psi and then SLOWLY climbs to 5psi. I'm not at 5psi until 5,000RPM, whereas I used to be at 5psi at around 3,000rpm (which is about where I build 3psi now). So I tried putting the washer I had back in to tighten up the BOV...but then it started it's stalling act again. So I'm thinking either I should find a very thin washer, OR maybe the BOV is not getting a very accurate vaccum signal. Any ideas?
