WhitewaterPearl
- 2006 Mazda5 Touring
I need some help with my rear suspension. My wife's 2006 MZ5 has worn thru two sets of tires in 18k miles. Tire rotations were done every 3-4k miles and has had four alignments. The first 3 alignments done by a Goodyear shop adjusted the front passenger side toe twice probably due to her curbing the tire and the rear cross toe was out of spec each time.
I emailed Mazda recently who responded they were not aware of a rear tire issue and I should have my local dealer look at the car. My local dealer said they have seen a few Mazdas that wore the inner edge of rear tires but there is no fix available thru Mazda. I asked if I could have 2009 rear suspension parts installed since their rear wheels are visible more vertical than mine. He said he couldn't because it is not authorized by Mazda. However, they did a free complimentary alignment (again having to adjust the rear cross toe), but said the rear camber was "within 2006 factory specs" and the only thing I can do is to keep rotating the tires every 3k miles. He took some up close pics of bald inner edges of rear tires and of the car from a distance to show how much the tires lean inward. I don't know the details but apparently Mazda told the dealer that if everything was within 2006 specs that they were done... Thanks Mazda!
So I have decided to fix my excessive rear camber issue myself. Which of these options do you all think is best before buying another set of tires?
-Install whatever 2009 factory parts that are different, (maybe too expesive if many pieces are required).
-Install the red Mazdaspeed camber arms.
-Install the adjustable SPC camber arms.
