rear water leak
bgibb68
'02 P5 Vivid Yellow
Just kinda curious to see if anyone has ever had water leak into the rear driver side corner. if so did you find where it was coming from? i've been fighting this leak for about 4 years now ever since a repair shop "repaired" a hit.
get you a coolant pressure tester or take it to a shop and have them do that and usually you can spot the leak once the system is pressurized. Hope this helps.
He is talking about a leak into the car from like rain...not a leaking coolant system....
Is it in the hatch? There is a how to by The Man to properly fix this.....I did the cheapo method and sealed the tailight housing to with some clear silicone....Most shops do not properly re-seal a important body panel seal, which is where the water seeps in...behind the taillights...
Search for the how to, or just pull the light and reseal the panel gap the cheap way...
