Rear motor mount replacement
I have the SU one and other than a bit of vibration for the first 500 miles I haven't had any problems, a lot less wheel hop, got rid of a lot of the drive train lash and just drives nicer. I don't know if the others have this option but you can change the insert in the SU mount if you want a stiffer or softer mount....
im getting SU MM to so i wanted to know how torque u used to screw it in???
Hello folks,
I have an 07 MS3 with the stock MM. After reading the last few messages here, I am gravely concerned about not having an aftermarket MM.
So what is a recommended aftermarket MM to buy and how do I go about installing it? I can search the forum for this.
I'd like to hear what other 'absolutely needed fixes should I do on my MS3?
Thanks
This past weekend I installed the Street Unit rear MM. Took 3 hours mainly because could not get the old bolts off. I tried BB balster, WD40, and my 6'4", 190ld all muscle 17 year old son. Nothing worked. Finally took a hammer to the socket wrench and it worked!. I strongly recommend the street unit and I think it does feel like there is more torque getting to the wheels. The vibration is hardly there.
Good luck
I am on my second SU motor mount. The first one I installed had the "aggressive" bushing. After a few thousand miles on it, it was still too much for my taste. I had dashboard rattling vibrations, exhaust drone and gear whine. It had a real sports car feel with all of this going on, but like exhaust can tend to do, it got annoying. I spoke with SU and they provided an estimated range of 75-85 duros for this mount! I believe it's every bit of the 85. My buddy gave me his extra 62 duro SU mount and I am much happier. I am going to sell my other one.
It'd be really cool for people to post videos of the supposed "Rattle" with the TRZ, SU, CP-E and AWR mounts for an objective comparison. I'd definitely hold up my end, I'm pretty set on the AWR.
i will post interior vids of after install, 500mi, and 1k mi to see the difference. i ordered the TRZ today so....
With the AWR its not noticeable enough to capture on video... Its probably the same with most of these mounts...
