FlyinHawaiian
- Mazdaspeed Protege #1460
Javo said:http://www.mazdas247.com/forum/showthread.php?t=123658465&page=4
This guy has a 4 lug and rear disk..
His is Euro Domestic Market... they came with 4-lug rear discs if I'm not mistaken...
shabaka said:step 1) press out 5lug axle
step 2) press in custom axle
step 3) bolt on 4lug hub
step 4) impress your friends
i hope you're only going that big on the front
on the rear it will look cool but 11-12" is way overkill
the weight and torque load will negate any performance gains in friction surface...
and it's not going to yield much better braking...if at all
10" is plenty big for the rear on a 2500lb
front engine/front drive street car
unless you are track driving for lap after lap and are concerned about fade
from overheating
shabaka said:sorry i'm a bit confusing when i type... my wife says i talk funny too
yes i have the specs and tollerances for the piece
you'll need two 2"x8" billet rods of 4340 stainless (...heck why not TiAl j/k)
no the bias is just fine seeing as the ES/MP3/MSP have the same part
you could upgrade to the 929 master cylinder tho
TheMAN said:you guys are making this more difficult than it should be
you only need to import 4 different parts then combine the rest of the parts you need off the 01-03 ES or P5 or MP3... parts which cost $400 AT THE VERY MOST... I'm sure it is possible to get them cheaper
you only need the JDM or EDM spindles, dust shield, and rotor, everything else you can get here
by doing this, you can reuse a bunch of other expensive parts such as your wheel hubs (which comes with the bearings) and find the rest you need at the junk yard cheaply
TheMAN said:rear spindles are about $110 *retail*
dust shield is about $24 *retail*
rotor is about $68 *retail*
Superprotege said:I am sorry for my ignorance but I still need some more help here. I really want rear disc but I want to go the chepest route in terms of not over spending and be left with unwanted parts. Again, I thank you for your input and direction.
Questions:
(1) I am still in need of a website, link or company to buy EDM/JDM Parts from.
Superprotege said:(2) Can I get a machine shop to customize a 4 lug or 5 lug shaft (from the junk jard) to fit into the 4 lug hub.
(3) Once I get the shaft issue resolved, is everything else just bolt in. I am planning to buy the entire subframe from a P5 . Is this necessary or will the custom shaft and a P5 spindle (of course all the P5 discs brake hardware- caliper, lines,etc) do the job and I don't have to get the 4 P5 bars (lateral links).
shabaka said:http://www.demon-tweeks.co.uk/produ...=Mazda&code=DIAGROOVE&app_id=146005&x=53&y=14
http://www.jennings-mazda.co.uk/service/parts.aspx
2)NOPE
3)SHOULD BE, 4lug lateral links SHOULD bolt up
shabaka said:the link is no longer up on the canadian forum where i got this info
but
quite trully this is easy with the axle swap
the guy who figured out the specs had a how-to
and...
1) 4lug lateral links worked fine on 5lug uprights
2) no geometry changed ie. offset, alignment travel, etc.
3) good luck finding a UK dealer, shipping is gonna be expensive
exchange rates suck $1.60+ U.S. gets you about 1 english pound
4) well, i guess i don't have a four...
i also checked part numbers on 5lug and 4lug latteral links
and got the same part numbers for both
this is only complicated if you over think it
your just putting a hub on a axle
TheMAN; much love i totaly dig your, indispensable, knowledge and website
much respect
TheMAN said:using the DX/LX lateral links on the ES/P5 spindle will cause the wheels to stick out too far... not to mention screw up the alignment
the DX/LX lateral links are 1/2" longer than the ES/P5 ones
whoever your source was for the part numbers was WRONG
there are importers here in the US who will be able to assist you in getting the parts you need
