goldwing2000
Mazdas247 OG
- 2018 Mazda6
2004 Mazda3 (sold)
2024 CX-5 (sold)
Possibly. Don't bet the rent on it, though. Unless you actually wear out the pads before 12,000 miles, you're pretty much out of luck.
goldwing2000 said:Yeah, those two little holes in the piston are for turning it back into place with a rear caliper piston tool.
K-D tools makes a good universal one.
http://www.thetoolwarehouse.net/shop/KD-3163.html
Moved to Suspension section.
hfaze said:Ok, I just went through this ordeal when trying to paint the calipers on my '04 Mazda 3 hatchback.
The calipers are PARTIALLY screw-down type. Screwing the piston in will only take it half way down. In order to get them to fully retract, I had to put a C-clamp on the caliper, and screw down the piston using an adjustable wrench. Using this method, the piston came down rather easily.
Mazda probably has some custom tool to do this in a snap, but these steps work out well for us shade-tree types... ;-)
Bluesv said:yeah, oil change 28$, brakes almost 300$, so yeah, thats a big difference, also I gat the car on 11/26/2003, and according to the dealer mine was the first one sold in the north america, but how do I check it out, dont know, plus i need that tool from the dealer to unscrew the filter, then pay another guy for used oil, takes too long and I would have to do it too often
