haveahotcarl
- 2003 Black Mica MSP
So, I installed new pads and rotors all around about 1500 miles ago. EBC dimpled and slotted rotors and EBC green stuff pads on all four corners. Since about 300 miles after I put them on the I can hear a "tish-tish-tish" (say it out loud, sounds just like that) noise coming from the back brakes that gets more rapid with speed. I know it is the rear b/c when I pull the e-brake, the noise subsides and I hear the regular noise of a slotted rotor. It isn't loud enough that I can hear it with the windows up but it is very noticeable with them down, especially when driving next to a wall.
Now I know it is likely a "normal" noise with the type of rotors I have but it is driving me insane and I want it to stop. I have the shims that came with the pads installed and the piston was driven back as far as it would go when I changed the pads. I have tried loosening up the e-brake cable but that solved nothing.
I hope that there is a simple fix that I somehow overlooked so I'll take all the suggestions you have. Thanks!
