Metro Gray
Metro Gray,
I am from Boston.
I'm in the S.Shore, almost between Boston and the Cape.
Any chance we can meet up when you change the resonator?
Metro Gray,
I am from Boston.
Wow, I'm sorry I was so slow in finding this thread. There are, indeed, a lot of us here who enjoy high performance and do not think drone is good.
The drone and total volume went up a good bit when I decided to go with catless DP/RP. Look at my sig. I can tell you that the 3 inch Vibrant Ultra Quiet Resonator is the real deal. This will help a lot. I'm as quiet or quieter than stock, and the drone is tamed, so if you still have your stock dp and second cat, this should really help with the drone. I put mine in the middle of the test pipe where the second cat used to be. You can put it just about anywhere behind your last cat, if any, and get the same result.
Note: We have a 2.8 inch exhaust system, so you will need to neck up to 3 inches to keep from losing flow. A good muffler shop should be able to install it for very little. These resos are a straight through design, so there is no power loss if pipe diameter is maintained.
Here is what I am tallking about:
http://vibrantperformance.com/catalog/index.php?cPath=1021_1033_1055
Drone induced headache gets old fast. It's a cheap fix. It's fun to be stealthy fast.
but let's face it. that is the way mazda wanted it... why hide it?.
obviously the creaks and groans and rattles and everything else is the way mazda wanted it. so don't mod your call at all. leave it 100% stock and don't change a single thing.
that means no modding ECU either. or winter tires. or replacement motor mounts. or short throw shifters. or replacement shifter bushings.
I have experience with Magnaflow exhausts, but on other vehicles. They are very high quality and typically very free-flowing. I know nothing about any CBE they may have for our cars.
The only Magnaflow product I have on my MS3 is the exhaust tip -- I wanted to downsize from our 4 inch tip (kinda ricer to me) to a more stealthy thin-wall stainless 3 1/2 inch tip that almost blends invisibly into the rear valance. It is very high quality and meets my perhaps unique needs.
But, here is the big thing: If you are seeking a power gain with Magnaflow or any other aftermarket CBE exhaust, please know that our CBE is so free flowing from the factory that there are no significant gains to be made unless you have modded your car so that it is capable of producing over 300 whp. The stock exhaust will flow that power level without loss.
As to the sound, you'll have to find sound clips and judge for yourself what sound you like. Change in sound to something you prefer should be your objective unless you are otherwise heavily modded (bigger turbo, etc) and have already addressed the area where the true restriction is -- ahead of the CBE.
To significantly increase flow, the stock DP and the two cats would need to be replaced by a properly designed non-restricive 3 inch DP that is catless or with high flow cats ahead of the CBE.
Honestly, I don't think the loud exhaust was "chosen" for either reason.
I think a free flow exhaust was chosen for performance. I think the sound was chosen based on focus group feedback -- the target age group for these cars is probably younger than you and me Metro Gray, and this is probably the sound that was most favored.
Performance was goal 1, marketing was goal 2. But that's just a personal opinion.
