I hope this is a simple question. I had water run into the floorboard on the driver side and my BCM got wet with lights on the dash, door locks and turn signals not working, etc. I want to remove the BCM and try to dry it out. I understand I should remove the negative battery cable. If I remove the battery cable, unplug all the connectors off the BCM, dry it and put it all back together, does that mess with the programming or should everything still be the same concerning BCM? I know it's a crap shoot if the BCM will work again. Just want to make sure disconnecting it would not cause a problem.
