Question about wheels (15x6.5 +30 offset)
Just wondering how a 15x6.5 +30 wheel on 195/50/15 tires would look? Will I run into any problems with rubbing if I lower it? Also how about gas milage/speedometer change?
I'd like to have it as close to flush as I can without using spacers. Does anyone have pictures of this set up?
Thanks
That's a plus zero tire size and will work great on those wheel specs. This car has a high offset range even dropped onto the ground. With a 6.5 inch wide wheel skys the limit (almost).
If you had searched a little you would have found this:
http://www.mazdas247.com/forum/showthread.php?123814567-TRMotorsport-C1M-Fitment-15x7-30
I have a very similar setup, 15X7 +30 on OEM tires, and if you slam the car, it will rub in front (with no camber alterations, only available through camber-bolts or STD R3 coilovers that come with camber-plates, the only coilovers ont the market that have those BTW). You will also rub in the rear on very big bumps taken at speed.
All false. You will rub with a 15X6.5 +30 on 195's, at slammed right-height (tire-tucking).
I rub all day, everyday when I turn the wheels in front, and rub on high-speed bumps at the rear. Hopefully my new coilovers will fix that because that have front camber-plates. A little rool on both end would hurt either.
Sorry for not searching. What would you suggest for specs if I don't do coikcovers (can't afford them ) should I forget about lowering if I go with this size?
Mine (in the thread linked above) have plenty of room with Racing Beat springs, but that's not a huge drop. I'm not sure if I'd trust it with anything lower.
The rear wheel well has a weird protruding hump for no reason that can be removed by cutting only rubs here when large bumps. As for the drop that's why I said (almost) some people have road grating drops and I would expect those to rub.
I would rather run a +35 or higher. A 6UL 15X7.5 +36 would look killer with a 205\50 on H&R Sport springs.
Not to be a PITA, but you said '...even dropped to the ground' in answering the OP about rubbing lol!
The hump you are talking about is a type of OEM bounding material. I would not cut it by fear of interfering between the inner and outer layer of the wheel well. A roll would be safer.
I went ahead and bought the set up. I also bought eibach springs, since I heard those are the springs mazda uses for their lowering kit. I'll post updates once everything is installed. Thanks for the help.
Thanks
I'm currently running 15x7.5 949racing wheels with 205/50/R15 Bridgestone Potenza RE11's. My Mazda2 is also dropped 1 inch in the front and rear with Bilstein Coilovers with NO rubbing issues what so ever. However I would have to run a spacer in the front to clear the bottom of the Bilstein strut if I were running 15x8 wheels.
