PTP's Smoking Turbo Fix
Actually I find information that I'm searching for by searching on Google. This will direct me to Mazda 24 7 threads. Every time I use the search on this forum, it brings up everything that is irrelevant. After doing some searching on Google, this is what i found:
http://www.mzspd6.com/forum/showthread.php?t=123751812&page=5
But I am still wondering how to install it. So I do know how to search, I was just seeing if I could gain a little more insight - rather than negative flak!
Disconnect the PCV hose from the valve cover end by squeezing the two tabs in, stick the pill in the exposed pipe and reconnect. 10 minutes, tops.
Sorry for being so harsh. The search engine here is, indeed, very poor. As you point out, Google is the best way to find things here: just start your search terms with "mazdas247" (without the quotes) and add your other terms. That works well and will bring you inside this forum.
There are just too many guys out there that don't even try to search, that I sometimes forget to be more patient with those who have tried and have trouble with the search function built into the board. My bad.
I bought the "pill" from PTP and it comes with picture instructions on how to put it in. You can't mess it up. I am as far away from a mechanic as a guy gets and I did it in just a few minutes.
On that note, it has not worked for me but my turbo seals may be toast and no pill will cure that ill.
By far the easiest thing I've ever done to a car. It took my I think 1 minute. It's ridiculously simple.
Didn't smoke before or after. Dunno why I did it, lol.
