Protege5 H7 headlight "springs" that hold in the bulb
Status
Not open for further replies.
shootz
Contributor
01 LX --> MP3 w/ better suspension!
Just like the title says... I need a set (both sides) of Protege5 H7 headlight "springs" that hold in the bulb. I bought a salvage title protege5 and the guy who had it before stuck in some H4 bulbs and screwed up the wires that attach the bulb to the inside of the headlight. I have all the screws, I just need the wires/springs/whatever you call them that attach the main headlight bulb (H7) to the inside of the headlight housing. Please let me know what you have, thanks... not looking to buy the who headlight.... if you did an HID mod to your Pro5 headlights, you would have these pieces... if you didn't throw them away. Let me know, thanks!
Unfortunately you cannot buy these anywhere without buying the entire light. As for those who have done the HID mod do you mean a retrofit or the plug and play? I have the plug and play and those spring clips are still very much needed to hold the bulb in.
Try a local junkyard if you haven't already.
yea, i should have rephrased it better...
i have the rear part of the P5 headlights w/ good bulb clips...
How much do you want for those little wires Turbo_Slug?
Status
