B bnasty28 Member Nov 25, 2002 #1 16X7 5lug-114.3MM a 42mm offset will these fit on my protege? can i use the same stock tire? im not sure what this whole offset thing is? thanks
B BlueMP5Dave Member : 2005 Winning Blue RX-8 Nov 25, 2002 #2 What type of Protege? What year? 2001 Protege ES wheels will fit every model made from 1999 to 2003. Provided you have 5 lug pattern.
7 70 Nov 25, 2002 #3 If the Protege has five lugs it'll fit. All the four lug Proteges run the same bolt pattern, all the five lug Proteges run the same bolt pattern.
B bnasty28 Member Nov 25, 2002 #4 the specs i posted is for an aftermarket wheel.... i have a 2002 es i was curious if the aftermarket would fit?
S scott42 Member Contributor : Blue MP3 #1169; '06 Subaru B9 Tribeca Nov 25, 2002 #5 are you replacing 15" alloys that you may be looking to sell by any chance?
7 70 Nov 26, 2002 #7 bnasty28 said: the specs i posted is for an aftermarket wheel.... i have a 2002 es i was curious if the aftermarket would fit? Click to expand... Yes, those wheels should fit...
7 70 Nov 29, 2002 #9 GXL said: Will this wheels fit on our P5s? Click to expand... What size, offset bolt pattern are they??
