are they the same for the protege 4 door ?? my question is because i want them, i asked this same question to a seller on ebay and he told me that the vent visors for sedan do not fit on the protege 5 , can anyone tell me??
The top rear corner of the door frame on the sedan is a bit rounder where the P5 has a strait edge angled door frame. I'm gonna see if the tape on ones that stick to the outside of the door frame can be trimmed to make it. Not seeing why the ones that go inside the window track like weathertec wouldn't fit both unless the door glass that rolls up is different sizes.
^^ Until you mentioned that and I looked at some pictures online, I always assumed that the sedan and P5 had the same rear doors. Thanks for making me check that out, and now I know they aren't the same.
Yes..in that pic the Vent Visor is Absolutely the shape of the rare Sedan doors...they are in fact..different as I thought.
No trimming would fix that fitment problem there.
Now if you could get some that did fit insde the window.....The Rear Glass that moves is he Same..Its just the Tri-window area that different between the two cars.
for in channel visors, i dont think the sedan rear visors will fit with a simple mod. it looks like it would have to be reshaped towards the end of the window as the top of our p5 windows are rather straight as opposed to the sedans curving down. as for the 3m attached visors go, they can be used but will be ill fitting.
Yeah, based on that pic I don't see that trimming the P5 ones would fit anywhere close to looking OK on the sedan & NO, the sedan ones definitely don't look near right on the P5. I haven't taken the tape on ones out of the box to even try, had a clutch master cyl to do for my truck. I'll still check but that pic makes it look like a no go.
I already have the weather tech ones but picked up a tape on set out of the pay it forward thread to see if they'd be close enough to work on a friend's sedan. He may have to go with fronts only if he wants them then I could trade the rears for the ones in that pic above & everyone would be better off. lol.
