Projector lamp
zobispo
Mazda CX-7
Does anybody know how to adjust the projector lamp? Because mine is uneven the left side is high little to high than right side.
Are you sure? Because I thinк the right side suppose to be little bit higher then the left side.
and my other question is that i notice it doesn't project much light out either. I install h7 hid kit 35w on it. is this normal or do i need to increase wattage to 55w.
which right. if im standing in front of the car the right side should be driver side or if im inside of the car?
Can the low beams be adjusted upward
There seems to be a top edge to the light pattern, probably to shade oncoming traffic. however the edge is rather low and I feel I am sometimes without enough light out in front of me when going down slight inclines or dips in the road.
