Update 10 September 2005
Well I promised another big update by the end of the week, and as promised I followed through.
First thing:
P7 Dead Pedal
Well, I've had this pedal for a few months collecting dust because I didn't have the thigns to prep it for installation at my disposal. I decided to go right ahead and clearcoat it first thing.
As you can see it turned out very well. When I placed it in the car to see how it would look, however, I didn't like the fact that I could see the plastic footrest on the carpet underneath it. I came up with the idea to make rubber inserts to fit through the slots like grip pads. I traced the inner outlines, then cut a certain depth into the rubber along that outline with an exacto knife. I then cut into the side of my blocks at the same depth, so it left a raised piece I could fit through the slots, as seen below:
Now it is mounted in the car, but I forgot to take a bloody picture, so I'll take one tomorrow of it.
Second thing:
New RIMS!
They are 17 x 7 RacingHart MSP Rims on 215/45R17 BF G. Scorchers.
I love the rims, I'm not a big fan of the tires, but they came with them. They are far to loud on the road compared to many others I have ridden on. I also put two locking lugs on each rim (different pattern for each) so that no one can do the "take off the other for lugs, twist the rim off and snap the entire lug off" trick.
The rims track much straighter out of turns then my stock rims, and the added size corners very well.
I also took it out on the highway, and though louder, I am ballanced much better and I can hit high speeds without even feeling it.
comments?
