UPDATE! Had to replace and fix a few parts over the past couple months...During the winter holidays, I had the unfortunate experience of having no choice but to leave my Cosmo in a shopping mall parking lot overnight because it was late and the 20B would simply not fire even though the engine was cranking over...
I informed my friend and the next morning he arrived at my place with a flatbed...We then went to rescue my lonely Cosmo.
Fortunately, the Cosmo started but it had flooded and took a while to idle smoothly after firing up...I then drove it back to the Mazda Dealer to get checked out...Here's what they found and repaired or replaced...
Crankshaft Angle Sensor (CAS): Sending intermittent signals to the ECU causing the Cosmo to occasionally not fire-up when cranking - REPLACED with Brand New OEM unit (NOT CHEAP IN JAPAN)
Water Temp Sensor: Corroded by rust and sending unreliable information causing the 20B to run super rich - REPAIRED, cleaned and reconnected with custom wrap to prevent water/moisture from causing the same problem in the future
Spark Plugs: After the CAS and Water Temp Sensor caused the 20B to run super rich, flood and ultimately not fire-up...The poor spark plugs were beyond cleaning - REPLACED all spark plugs with Brand New NGKs (took a while to track down the proper trailing plugs for the 20B but my friend tracked them down)
Optima Battery: I decided to take this opportunity while the Cosmo was in for repairs to replace the temperamental Optima Battery (red-top) so I don't have to worry if my Cosmo will start after a couple weeks etc - REPLACED with a Top-Of-The-Line Mazda Battery and after three weeks of no driving (been busy), the 20B started right up without a hiccup!
LifeWINK: A simple but wonderful LED meter that sits on top of your battery and tells you its current condition at ALL TIMES! It takes very little energy to run and also tells you if there is a problem with your battery and or electrical system (alternator). Another great feature is that Dealers and Repair Shops that have the LifeWINK reader can easily tap into the meter and see detailed data about your battery's cycles etc - INSTALLED and informing me that my new Mazda Battery is still fully charged (
http://panasonic.jp/car/battery/lifewink/index.html)
Just went for a blast through the mountains yesterday and the Cosmo ran like a champ...Happy to have the Cosmo running at 100% once again!
