Ok most of you either don't know how to use a pressure washer correctly or are just plain blind....
I am not going to get a 4000 psi pressure washer and stick the nozzle right against my paint...
BTW I bought a 1500 psi one from Simonize. I got an amazing deal on it....
On the car paint itself, I will use the mild nozzle, about 1500 at high pressure and 1000 at low... that pressure is right after the nozzle tip itself, i will wash the car about 6-12 inches away which greatly reduces the pressure.... just enough to remove some dirt but not all.. the main reason for this washer is to clean the brake dust off my rims and to clean my wheel wells... I can't stand sitting there with a brush or mit cleaning them.. it's my pet peave.,.. So I will blast away the dirt right off my rims... LOL
If you use the tool properly it cuts down your work time by alot but can be damaging if not used properly. I already take 7 hours to restore my pain in the fall I don't need to spend 1 extra hour cleaning my rims....
I have used a pressure washer before but thanks for the warning in advance.
Jc
