My car is exhibiting what appears to be worsening throttle response, taking up to a full second to respond to throttle input. Power is defintely fine, just the response is delayed. This delay in a manual transmission car can mean a stall when starting uphill, forcing you to use the handbrake. I'm not sure if its the ECU or the throttle-by-wire causing the problem.
I first noticed this problem when I tried to launch hard like I did in my old civic and found that pressing the gas didn't do what I expected, and the car just barely wheezed forward without sufficient revs. I'm used to the motor jumping to my requested throttle input right away, and then loading the motor with a full clutch release simultaneously. What resulted in tire chirp and aggressive foward movement in my civic has much a more cathardic response in my MS3. I heard this is called "Throttle tip-in" and is usually the cause of latent drive-by-wire systems.
I asked my dealer if there's an ECU reflash to fix this, and here's what they replied with:
"We would need to book your vehicle in to run a scan, to deterime if there
is any updates, i do not believe there are any related updates, unfortunatly
there would be a charge of $94.00 + taxes to scan the system. if there is an
update then we can charge that to MCI."
Anybody get this fixed, through dealer or otherwise aftermarket applications? Or do I get used to it and then sell the car for something older with a hard wired throttle. A laggy gas pedal is not what I'd consider "sporty".
