Playing MP3 CD's
I'm having a problem when I'm playing an MP3 disc. When I make one using almost all the available sopace on a cd, the deck won't read the disc. I made a test cd with only 50-60 mp3's and that worked. Is there a limit you can put on a cd in order for the deck to read it? :confused:
as long as u have enough space on the cd u should be able to put on average 150 songs and I like a lot of Dance, rap, techo, etc...which are longer songs...My cds are 700mb...Make sure u burn all the songs in ONE FOLDER...
good luck!!!
good luck!!!
Why? I have a couple disks with 12 folders. That should have nothing to do with it. The only time I've run into a problem like you're having, MangoSpeed, was when I was running out of space on the drive I was using. The burner utility has to create temporary files before burning the disk and when it runs out of space, it can't download the file to the disc. The file format, however, will be there so if you check the disk on your computer, it will look as though all the songs are there. Make sure the drive you're running the burner utility has enough space...at least as much as you're burning.
