Pootie Tang
Cool! How did you remove the gate? Does it just pop off?
There's a thread in this forum I think, that explains how to remove it. Generally, you pop up the cubby under the HVAC controls by inserting a flat blade (taped is a good idea) screwdriver between the center console gate area trim and the cubby edge about 1.2" from the left edge of the cubby. The cubby pops up and rearward. You then reach under the front edge of console gate area trim and lift. The trim pops up at all corners.
Oh, and you need to unscrew the selector knob first to lift the trim off.
