Recently had the alternator belt fail and just got around to investigating the cause and fixing it. I noticed that the passenger side motor mount was looking really bad, and that one of the male "studs" coming from the engine block had actually snapped off. The broken stud is the one that normally has a ground wire attached to it. The ground wire let the broken part of the stud dangle against the belts until it failed.
So. Big problem. Is the stud on the block side of the motor mount replaceable? Is the entire block side mount replaceable or is it integral with the block?
