6 happy days spent with my new CX-5 - love the car.
Having read some other threads on here I'm slightly confused about the Passenger Airbag.
Is it normal for the words 'Passenger Airbag' to remain permanently illuminated on the centre display, with or without a passenger in the seat, after the 'On' signs goes out?
I'm assuming it is OK, but was wondering if it might be an indication of an error - This would be the first car I've had where any airbag sign stays on without there being a problem with an air-bag
Thanks
Read the manual, do not rely entirely on reading internet threads without the context of the manual. If you have concerns, see the dealer and demonstrate the potential problem.
"To reduce the chance of injuries caused by deployment of the front passenger air bag, the
front passenger seat weight sensors work as a part of the supplemental restraint system.
This system deactivates the front passenger front and side air bags and also the front
passenger seat belt pretensioner system when the front passenger air bag deactivation
indicator light illuminates....
"...Your vehicle is equipped with a front passenger seat weight sensors as a part of the
supplemental restraint system. These sensors are located under both of the front passenger
seat rails. These sensors determine the total seated weight on the front passenger seat and
monitor the seat belt buckle for the front passenger seat. The SAS unit is designed to
prevent the front passenger front and side air bags and seat belt pretensioner system from
deploying if the front passenger air bag deactivation indicator light illuminates.
system deactivates the front passenger front and side air bags and also the seat belt
pretensioner system when the front passenger air bag deactivation indicator light
illuminates. Refer to the following table for the front passenger air bag deactivation
indicator light illumination conditions.
"This system shuts off the front passenger front and side air bags and seat belt pretensioner
system, so make sure the front passenger air bag deactivation indicator light illuminates
according to the following table.
"The air bag/front seat belt pretensioner system warning light flashes and the front
passenger air bag deactivation indicator light illuminates if the sensors have a possible
malfunction. If this happens, the front passenger front and side air bags and seat belt
pretensioner system will not deploy.
"If the front passenger weight sensors are normal, the indicator light illuminates when the
ignition is switched ON. The light turns off after a few seconds.
"The front/passenger air bag deactivation indicator light illuminates or is off under the following conditions:
[the table does not copy well]
Condition detected by the
front passenger occupant
classification system
Front passenger air bag
Front passenger front and
side air bags
Front passenger seat
belt pretensioner
system
Empty (Not occupied) On Deactivated Deactivated
Child or child-restraint
system*1 On Deactivated Deactivated
Adult*2 Off Ready Ready
*1 : If a larger child sits on the front passenger seat, the sensors might detect the child as being an adult depending
on the child's physique.
*2 : If a smaller adult sits on the front passenger seat, the sensors might detect the person as being a child
depending on the person's physique.
The curtain air bag is ready for inflating regardless of the chart above.
"If the front passenger air bag deactivation indicator light does not illuminate when the
ignition is switched ON and does not illuminate as indicated in the above chart, do not
allow a child to sit in the front passenger seat and consult an Authorized Mazda Dealer as
soon as possible. The system may not work properly in an accident."
