Paddle Shifters for CX-7
I made an effort to add shift paddles to my AWD-GT using two RF remotes, one for each side of the steering wheel. I decided to make the right upshift, and the left downshift as this seems fairly standard across other cars.
My first idea was to borrow the shift paddles from the Miata GT, but this would require changing the steering wheel, or perhaps cutting a mounting location into the CX-7's wheel. The Miata's paddles upshift with the "UP" paddle, and downshift with the "DOWN" button, the same on the left and right sides. They were asking $140 for each paddle. It seemed better to make my own for the CX-7.
Miata GT Shift Paddles
I made my paddles wireless, to avoid the need to wire through the steering wheel. They're attached to the back of the steering wheel by a bracket fastened with the airbag mounting bolts (under the rubber plug)
The RF receiver was installed under the console in front of the shift lever. The existing wiring is fairly simple. A 6-wire connection carries the signals for Upshift, Downshift, Drive/Manual, Ground Return, and two wires for the small lamp.
I had to add a few relays to ensure the shift paddles will only function when the gear shift is in the Manual position, and also to ensure you cannot shift in opposite directions with the paddles and shift lever
So far I have not noticed any interference while driving, I think the chance that someone has the same remote with the same code is pretty small
I find I still use the shift lever sometimes, when turning for example, but for the rest of the time it's pretty cool to rapid-fire shift without moving my hands from the wheel.
Left Side Shift Paddle
Right Side Shift Paddle
Overhead View
Overhead View
