Has anyone tried notching the crank angle sensor mount to advance the timing on a P5? This works on an M2 Miata.
Also is there any trick to accurately measuring the timing. On all Miatas you have to jumper the 10 and gnd connections on the diagnostic plug. Is there a similar procedure for the P5?
