I recently bought my wife a P5, and due to other issues, have been driving it alot. In general, I love the car, especially the way it handles at low to mid speeds, the balance of the car, and the higher speed stability.
One issue I have been finding though seems to be the steering response, or rather the power steering and the level of feedback it suppresses from the road.
I have found that the higher the speeds, the more the feedback from the road moves the steering wheel and thus determines the line the car takes across the road, and sometimes drastically enough that I have had to cut back on speed by 10-20mph. Of course, with the highly sensitive brand-new brakes, that is risky as well, since they grab the wheels too hard for cornering, and increase the problem. I have tapped the brakes in a couple instances, (and i mean 'tapped', just a light touch) and have had the steering wheel jerk to one side, usually the inside of the turn.
Do anyone else have this problem? And if so, is there a common solution or fix? A higher power-assist level should dampen the effect, but not sure if this is the actual problem, or if it would be the correct solution.
One note that might matter, this is the first car I have ever driven with "Speed Sensitive Steering", and if this is the direct side-effect, then ... well, I don't like it.
