Hello,
I just installed my front door component speakers and since I took a lot of pictures of the process, I thought sharing them would be a nice idea for some of you out there.
This is not meant to be THE WAY to do it but simply how I did the job, and you're sooo welcome to agree, criticize, add your own stuff or simply forget about it since anyway you already have a set installed a while ago...
So lets see, first this is the OEM speakers, a set of dual-cone drivers with a DIN input power level of 25 Watts. They don't sound that bad as long as you don't open your windows and the stock deck power output is enough for you...
(then maybe you should be reading about forced induction or something like it!).
Now this is how it will look after you unscrew the speakers. Wait! don't throw 'em just yet...!
What I did was to take the plastic rain guards off the OEM drivers so I could use them later. You'd be surprised at how much water slips between the window's glass and the rubber molding in your doors !!! The speaker on the left still has the rain guard glued to it.
Now this is where you get your $4.20 piece of MDF from Home Depot, a Jig saw, use the OEM speakers as a template, and draw what it will be your new 6.5-inch speaker plates. For the speaker mounting hole you'll need the template provided with your new drivers, and those are the first holes you want to do, the wood will be easier to handle that way.
OK, now on the left you can see one of the custom made (sounds cool ah?
) wood speaker-mounting plates, with the rain guard already attached to it.
