P0113 and P0660
03.5 MSP
the other day driving home my new MSP tripped out and the check engine light started blinking on me and it started driving like a blew a coil pack. swapped them out and everything was fine. driving it again today for the first time in a few days and it read codes P0113 and P0660. i did a little research and found that its the VICS solenoid and the intake air temp sensor? what exactly should i do to fix this?
i just swapped over my TurboLife FMIC and piping from my silver MSP (which includes a relocated MAF)...
If the IAT sensor is plugged in then it may have failed, same with the VICS sensor. I would grab a couple from a JY if you can, they are expensive new.
Vic's solnoid won't actually trip the cel it's probly been like that for awhile, mines been bad for years but I don't run it hard so not worried about replacing it
^ def hasn't been like that. didn't happen until my piping/relocated MAF and FMIC were swapped over
The codes could have been stored previously or may have popped up if you unplugged or messed with any of the sensors while the car was running.
