It wasn't until I had swapped a P5 radiator for a PWR unit that I had the ScanGauge to tell me the actual water temp number. On track, with the heater on full blast, the car runs 225-240*F but the stock gauge barely moves if at all while its running this hot. Because of this, I don't know if I has overheating with the P5 radiator.
Cooling system: PWR radiator, 2 fans, heat wrapped lower radiator hose, new Tstat. System holds pressure, cap holds pressure, cylinder compression is perfect. Temp sensor is functioning properly. 80K miles on water pump, but no leaks around gasket. Water temp flucuates 20+*F once up to temp so the water pump impeller seems to be spinning. Exhaust leak between turbo and manifold is contributing to the heat. System is properly bled.
Even cruising around town/highway with holes punched in the t-stat the car will run 205-215*F. I purchased a Gates lower temp tstat only to find its a stock temp tstat. The holes in the tstat slow the time it takes to get hot, but doesn't reduce final temp.
Anyone have any suggestions? Please do not make suggestions without an explaination. Exhaust gasket will be changed shortly.
-Marc
-Marc
