2008 Mazda CX-7 overheating…Help
I have a 2008 Mazda cx-7 that I have recently replaced the radiator, thermostat, temperature sensor, and it’s still overheating the head gasket is good from my knowledge no water mixed in the oil no water or smoke from exhaust
i can idle the car all day fine but as soon as I shift into drive and move it pegs to hot ive released all air in the system with the car cold I can’t even start the car without coolant spraying outta the radiator with the cap off like a geyser and with the car running all the fluid seems to completely fill the overflow tank I remove all the fluid start it again and the overflow tank fills again I’ve also replaced the thermostat again with a oem with no change plz help
I just went through this make sure you burp your radiator good rev it to about 4000 rpm for 5 mins let idle for 30 sec and repeat about 3 times
New Threads
