Jackie chan
- Pro5
Puttin' it to the test I see, haha.
Sent from my SM-G900T using Tapatalk
Nice. I will likely use this idea when I make mine. I would love to have a full underbody panel to streamline airflow
Does that Alucobond flex any? Can you mold it? Working on a diffuser and was looking for something to make it out of that didn't include cardboard lol
It's pretty good to work with. It can be bent to make soft curves but not solid angles. Easy to drill through, easy to cut and shape and easy to paint. I'll be starting my rear diffuser soon out of the same stuff.
I want to do a flat floor as well, but the chassis rails under the car are lower than the sills themselves. So it will be hard to get it completely flat, although I think I have a solution for it. 3 sided aluminium and screwed into the sills.
I think with the diffuser itself that the spare wheel well is in the way as well as the back panel. I'm going to get another bumper so I can cut it up a bit and experiment with it.
I would need short curves, about 75deg turn at 1.25-1.5" radius. Too small?
Depends how deep you want to go with the diffuser. You can get about +10-12deg from the underside of the spare wheel well to the bottom of the rear bumper cover. You can go quite a bit deeper by cutting out the rear valance, but I think the spare wheel well makes a good starting point. You want the start of the diffuser to be at level with your underbody panels, I don't think the spare wheel well drops lower, but I didn't measure it either..
If you're going to race the car, the Autoexe chassis braces are something to look into. It's a 5 pc kit and really stiffens up the chassis and suspension. The downside is that they would interfere with the single-surface underbody paneling
The biggest downside of all is it not being able to buy it xDAnother downside is they arent even available on the website i just checked...
Sent from my LGMS550 using Tapatalk
Lol I like it. You need fender flares with that! And some 16's, you need to get that splitter within 1 inch (2.5cm) of the ground![]()
