Open Source (Linksys WRT54G)
Very interesting. That's the power of the GPL.
<-- walks downstairs to find out what model number router he has.
Yup my Linksys wireless router isn't 'stock' lol. The reason why I picked the Linksys was simply because of the fact that its firmware is open source and upgradable. I could even modify it myself if I was ever so inclined.
I've got a WRT54GC. Only a letter off and looks cuter, but none of that stuff is available to me, unfortunately. Luckily, all I need it to do is work as a router/access point, and work well.
so without me clicking that link and reading the article what can i make my router do that it doesn't already do. does it work better?
that's kinda wild. i don't know what i'd need to upgrade it for, but i have 2 WRT54Gs, one for home and one for home at school. i'm not completely understanding the article, but i'm gonna look at those other firmware sites that can flash new firmware on and see what features they have
w00t, i need to get one of these routers. I see a dirty scheme im hatching.
Here's the skinney:
If you want to do this, STAY AWAY FROM VERSION 5 (the latest) of the WRT54G, as it nolonger uses the Embeded Linux Firmware, and is rumored to have less RAM, and Storage. I found out when I unwittingly got mine from Best Buy on Saturday afternoon. Come 11 P.M., I found the warning here, and was able to go to Walmart and pick up a Version 3 (CDF8) for $50. I had to call Gimpo02 up on the phone to look up the serial numbers for me since I forgot my list at home. Props! I returned the version 5 to Best Buy the next day. Versions 1-4 are what you want. How do you know which version is which? Here is a little hint:
Before you buy find the Linksys sticker on the outside of the box (or bottom of your router if already open). Find the serial number (S/N) and most importantly the first 4 letters of it.
Secondly, look below to find your hardware version.
CDF0 = WRT54G v1.0
CDF1 = WRT54G v1.0
CDF2 = WRT54G v1.1
CDF3 = WRT54G v1.1
CDF5 = WRT54G v2.0
CDF7 = WRT54G v2.2
CDF8 = WRT54G v3.0
CDF9 = WRT54G v3.1
CDFA = WRT54G v4.0
CDFB = WRT54G v5.0 <-- STAY AWAY FROM THIS VERSION!!!!
CGN0 = WRT54GS v1.0
CGN1 = WRT54GS v1.0
CGN2 = WRT54GS v1.1
CGN3 = WRT54GS v2.0
CGN4 = WRT54GS v2.1
CGN5 = WRT54GS v3.0
CGN6 = WRT54GS v4.0
SJH0 = WTR54GS v1.0
Know that the GS models are faster, and have more RAM for customization.
Here are just the features of the DD-WRT firmware Upgrade:
  • Hotspot Portal (Chillispot (http://www.chillispot.org/))
  • PPTP VPN Server
  • 2-way Bandwidth Management (incl. P2P, VoIP, IM)
  • SSH Client and Server (dropbear (http://matt.ucc.asn.au/dropbear/dropbear.html))
  • Telnet
  • Startup, Firewall, and Shutdown scripts
  • WDS Repeater Mode
  • Client Mode (supports multiple connected clients)
  • Adhoc Mode
  • OSPF Routing
  • RIP2 Routing
  • Power Boost Function (max 251mW power)
  • Select Antenna
  • Static DHCP Assignment
  • DDNS
  • Clone Wireless MAC Addresses
  • VLAN
  • WPA over WDS
  • WPA/TKIP with AES
  • WPA2
  • Client Mode WPA
  • Client Isolation Mode
  • QoS Bandwidth Management
  • Port Triggering
  • Port Forwarding (max. 30 entries)
  • Wake-On-Lan
  • Remote Syslog
  • Remote Ntop Statistic
  • Xbox Kaid
  • SNMP
  • IPv6 Support
  • Show Status of Wireless Clients and WDS with System Uptime/Processor Utilization
  • Site Survey
  • Remote NTP Server
  • 12 languages
  • Style (Changeable GUI; v.23)
  • Supports New Devices (WRT54G V3, V3.1, V4 and WRT54GS V2.1, V3, V4), however not WRT54G V5 as this uses another OS and has less memory.
Until the WRT54G came along, these used to be exclusive features of expensive Cisco routers in the $1k range. It is in our reach for under $100. You also have the added bonus of having a little low-powered Linux box running.
I had this router and the wired ports went bad on it.. I was pretty pissed
LinuxRacr said:
Did you mod it at all?
nope.. wasnt' aware of its capabilities.. I scrapped it about a week ago and picked up a netgear MIMO router
I still have it if anyone wants it
::snip::
I'm an idiot.. just checked the actual model and it is a wrk54g.. different model.. sorry bout that
::snip:::
