Open door light keeps coming on
steve333
2013 Mazda 3 iSport Automatic SkyActive
I had this issue in the past and it just resolved itself. I don't open my rear doors because that sets it off, but I just had my car detailed and the problem is back. The door open light keeps coming on even though the doors are closed.
Sometimes when I click on the lock all doors/unlock all doors button the light goes away but overnight it apparently came back on since it was on when I went to the car today. The biggest issue is that it seems to drain my battery.
Is there a fuse that can be removed to keep the light from coming on and would that solve the battery drain issue? I assume it would cost a good amount to get fixed.
Thanks
2013 Mazda3 Automatic Sedan
There's a fuse but it might control more than just the lights. Are you talking about the lights near the rear-view mirror. If so you can toggle them off by using the little rocker switch. If the rear passenger seat lights also stay on you can pull the bulbs.
It's a light on the dash. The lights inside the car don't stay on as I turned those off anyway, just the warning light on the dash.
I had my service place lube the door and the problem hasn't come back so far, at least until the next time I need to open the rear door.
