Passenger side low beam went out last night coming home from work...I installed a xenonexpert hid kit, figured the ballast burned up or bulb. Bulb is fine, so I went straight to the 12v source. No power on the lamp connector harness. So, its either a short in the wire, or the headlight relay, which has to be in front of that. Right?
Can't seem to find that relay...for the headlights, is it under the dash by the steering wheel? I can't get a definitive answer from the posts, and the manual says zilch. Anyone dealt with loss of power to a headlight can help, would apprec(2thumbs)
