OK which 1 of these oils would you pick
Which 5W-30
  • Penzoil
    Votes: 3 10.0%
  • Castrol Syntec
    Votes: 26 86.7%
  • Quaker State Peak performance
    Votes: 1 3.3%
  • Total voters
    30
You know that might work...just draw the oil from the bottom of the oil pan filter it and dump it back in to the top of the pan. The Amsoil system allows for two different methods one that remotely mounts both the bypass filter and the regular filter and another that draws a small amount of oil from the OP sending port. Both of these methods rely on pressure from the engine driven oil pump.
flyguy
RyanJayG said:
so basically you need a sump and a .5 micron filter to pull it off... interesting. we have stuff just like this at work that I could "borrow". hehehe :D
we have some really nice filters and filter heads that we use to filter the hydraulic oil into the EDC of our Sauer Sundstrand pumps (about $30,000 a pump). and I know we have some small electric gear pumps lying around... this could be my next project. :D
flyguy
hmm, yeah, I would tap the oil pressure line, put in a snubber and just filter it and dump this small volume right back into the oil pan... then I wouldn't even need the pump... though with an electric pump I could rig up a cooler for oil cooling without running then engine, for when I go turbo. turbo timer-ish with out the hassle
lamp3 said:
none if it were me. mobil 1 all the way baby!
Same here....just put it in my car, and the engine is smooth as silk! I used 10W-30 as well.
