I have a 2001 Mazda Protege ES 2.0 5spd. I've installed a......
J-Spec Intake Manifold(FS-ZE)
Bosal 4-2-1 Header(93-95 Mazda MX-6)
Custom 2.5" Cat-less exhaust system.
I installed the intake manifold myself. Then 3 weeks later i had the header exhaust system installed. Did a dnyo pull. Picked up the car. On my way home excited from the mods that i had done i decided to hammer it a bit off the light. POOOF!!!! The blueish/black smoke coming from my tail pipe was insane. So i installed a air/fuel ratio gauge. At WOT the car runs pig rich.....it has been running rich for a month now. I took to a garage here, and the mechanic noticed the the vacuum lines for the VICS and VTCS controllers where installed backwards. Forcing the VTCS to stay shut. Fixing this problem toned down the richness a bit.....Also not to mention that my EGR is blocked. Then he ran a compression test, and a leak down and everything is fine. Its the fact that i'm running rich.....Why the hell is this occuring? Could someone shed some light onto my concerns.
