No - it does have relevnce -AJsMSP said:I installed an Autometer Oil Pressure guage and left off the stock sender and just attached the provided sender for the gauge. Now if I remember correctly I read somewhere that if you do this that the oil light will come on in the dash. I haven't had it come on since I put it on two days ago and I am getting good readings from the gauge...about 12 psi at idle. This has little relevence in regards to the original post put I thought I would just throw it in.
pdhaudio83 said:i just got a mechanical oil pressure gauge.
NOTE: to SAFELY have oil in your cabin, copper tubing is a MUST!!
buy autometers copper tubing. its like $10 and includes fittings.
i havent wired it up yet though.
Yep -xXxJIGGAxXx said:Yo Horse! Are you the same Horse on CEG? I be the BStoneMega over there. Cool. Small internet huh?
me tooxXxJIGGAxXx said:I haven't seen him here yet, he is the one who refered me to this site.
I found everything you need to install an o/p gauge by searching....Murda said:Search bud!
I have a Defi Electrical Oil Pressure Gauge. Hooked up with a t-fitting to keep the stock pressure sensor hooked up.
Lots and lots of thread discussing this with exact sizing and pictures.
