Oil leaking
chopperman
Mazda Protege 5
I have oil coming out of what I think is called the manifold. Its the part where the spark plugs go into. The oil is comeing from that seal, If I look right above the exhaust header that is where oil is coming from. Does anybody know what the problem can be. Mabe its just the seal?
Agreed.
Remove the Coil Packs and then remove the cover in a sealed area.
Get the new gasket in the groove in the cover.
Make sure none of the metal tube pieces are missing. It's what controls the level of the seal..
