holly sheep s*** that doesnt look too good did you identify to make sure its oil? If so make sure to tighten up the clamps but that right there my friend might be a bad turbo.
Bad turbo? Isn't it transmission right there on the Opposite side of the turbo?
Find out what kind of oil that is - transmission oil and engine oil small/look/feel differently so once you know which one it is, you'll have a better idea.
Also, jack the car up and see how much of that stuff is under your tranny and maybe it'll give you a better idea of where it's coming from.
Keep an eye on the liquids.
Nope,the seal is probably leaking cuz it's 4 years old and cracked...So what are you saying? Is the trans heat enough to blow some fluid out the shifter seal?
The car is at a steelership right now,i'll keep you guys posted on want they did.
I know three other members that had the same problem....Probably due to heavy driving I have never seen this from normal wear but its possible
Am I just getting old...?
Learn how to spell.
My head hurts from what you typed.
I've seen bad, but that's ******* bad.
Learn how to spell.
Wow [Cody?]. Learn to take a joke man. I was just messing w/you.
